The text in the cart is still white and not visible
Thread began 7/18/2013 9:41 am by zinlover320832 | Last modified 7/18/2013 10:39 am by Jason Byrnes | 343 views | 1 replies |
zinlover320832
I cannot find the path to edit:
1. http://www.mmoliveoils.com/PowerStore453/PowerStore%20Files/admin/design_settings.php?Editing=mmOilveoils
product numbers are in white
2. http://www.mmoliveoils.com/PowerStore453/PowerStore%20Files/products_detail.php?ProductID=1
a. World of Hurt Price: $30.00 is in white
b. Extra Virgin Olive Oils / Co-milled Flavored Olive Oils - I need to change the color
3. http://www.mmoliveoils.com/PowerStore453/PowerStore%20Files/cart.php
a. You shopping cart and coupon code are white, needs to be changed
b. World of Hurt. Global chilies, Arbol, African Birdseye, Pequin and Tepin are added to our Extra Virgin Olive Oil to make oil with multiple layers of flavors and heat. At first you taste the fruity olive oil then you’re& - this is in purple, needs to be changed
Thank you.
Stuart
1) You can change that color in the settings.
2) This can be changed in the design settings also by changing to the Catalog section and changing the different color options for the catalog
3) Again, this can be changed in the design settings by changing to the cart section and changing the colors.
