Form Fields from DataAssist
How do I re-size the form fields generated by DataAssist they are all short and same size? I have tried to add size="" to the form field but alas.. it doesn't work..
The form field size is set in the css.
each of the Form preset designs will have a small medium and large setting fro the different form element types.
In Data Assist wizard, on the Manage pages tab in the Field settings, you can set the form element type and size to use for each column in your table.
if you need to make changes after the pages are created, you can either change the CSS class for the form element, or edit the CSS
