Error suddenly on server. IT person insists its on the website.
Thread began 7/15/2013 7:52 pm by wbrooks199805 | Last modified 7/16/2013 10:45 am by Jason Byrnes | 142 views | 1 replies |
wbrooks199805
This is showing on this website globaltvconcepts.com Is it the server settings, global settings, Mysql settings or is it the website?
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in/usr/home/glob34/www/htdocs/images/installed.png on line 2
Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in/usr/home/glob34/www/htdocs/images/installed.png on line 2
this error when the date.timezone setting in the php.ini file is left empty.
you should have the host edit the php.ini file and set a time zone for the :
date.timezone
setting.
