wizard, database set up
I have errors in the data base. Attached are screenshots. What am I doing wrong?
the error is pointing to a problem with the username or password.
double check that you are using the correct username and password.
I double checked and still got the same message.
https://p3nlmysqladm002.secureserver.net/grid50/6483
Thank you
