CSS Menu Writer
Thread began 7/14/2013 9:45 am by Simon | Last modified 7/16/2013 5:13 am by MikeyT | 904 views | 3 replies |
Simon
CSS Menu Writer
Lets say i have created a preset navigation bar and have inserted it in a website that is 50 pages, Now later i need to make a change to the structure of the site and i need to add more buttons to my navigation bar. Is there a easy way to do this?
So far i have made the changes in the wizard and then saved as preset, then on each page deleted the old navigation bar and inserted the new.
This is OK if i had only a few pages but for larger sites would not be very good.
Please HELP!!!
MikeyT
Library Items, Includes/Plug-ins
There are a few different ways you can accomplish this and make the process of updating the menu easier. Basically, you want to create one instance of your menu and have it linked to all your pages. Update the menu as many times as you'd like, and the changes are reflected site wide.
If you have a plain html site:
• You can use Dreamweaver's Library Item functionality. Checkout DW's built in Help for this one or just do a Google search for it.
If you have a php site:
• You can create a menu include either the traditional way: http://www.w3schools.com/php/php_includes.asp OR if you happen to own Framework Builder you can create a menu plug-in and insert the menu as a "static" plug-in.
If you're new to this concept, the bright side is that all of these methods are pretty easy once you do it a few times. And they will save you a ton of time when updating site content. I build most of my sites this way... breaking out parts of the site into separate includes or plug-ins, such as header, navigation, footer, etc.
Hope this gets you headed in the right direction.
Simon
Thanks.
GREAT.
Thanks for the advise.
MikeyT
Anytime.
