Unable to add, edit or delete content when logged into Power CMS on remote server
Thread began 7/10/2013 4:13 am by Rune Brynestad | Last modified 7/10/2013 9:46 am by Rune Brynestad | 434 views | 2 replies |
Rune Brynestad
Once logged into PowerCMS I can't see the content - I am unable to insert new content, view/edit or do anything with the content. No error messages are reporting on the index page.
I'm able to use all the other facilities in Power CMS (Manage users, search, settings and so on), but the most important part does not work.
It works perfect when I'm testing it on my localhost, but not on the remote server.
Regards
Rune
the problem is case sensitivity.
you have a folder in your site named "JS". the CMS install added a number of files to that folder, but the CMS code is expecting the folder to be name "js" (lower case). since your is a unix server, the case of the folder name maters.
you will need to change that name of that folder to lower case "js" and update your pages that use scripts in that folder to use the lower case folder name.
Rune Brynestad
Yes, that was the error. I have done similar mistakes with the image folder a few times, but I forgot about the js folder.
Thanks a lot for looking into this.
Regards
Rune
