Logout Doesn't Seem to Clear Cache
Thread began 7/03/2013 11:28 am by anonymous | Last modified 7/05/2013 2:02 pm by anonymous | 1186 views | 4 replies |
anonymous
Hi. When a user logs out of the customer portal I created with Data Bridge and eCart, he is directed back to the login page. However, when he tries to log back in to the portal without clearing the history, he is directed to the failed login at "login.php?failedLogin=1." He has to clear his history before it works.
Please help. Attached are the login and logout pages for your reference.
Thank you!
Heather
login.php
logout.php
anonymous
Thanks, Jason. Below in the private message section is the info you requested. I'm still testing the entire site, so I may be making some small updates here and there but nothing that should affect your troubleshooting.
i corrected the problem by adding the following code to line 1 of the login page:
@session_start();
$varQS ""
    if(isset(
$_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "") {
$arrQS explode("&"$_SERVER["QUERY_STRING"]);
        foreach(
$arrQS as $k => $v) {
$arrVar explode("="$v);
            if(
$arrVar[0] = "accesscheck" && $arrVar[1] = "%2Fportal%2Flogout.php%3F") unset($arrQS[$k]);
            if(isset(
$_SESSION['WASA_accesscheck']) && $_SESSION['WASA_accesscheck'] = "%2Fportal%2Flogout.php%3F") unset($_SESSION['WASA_accesscheck']);
        if(
sizeof($arrQS) > 0) {
$varQS "?".implode("&"$arrQS);
$_SERVER["QUERY_STRING"] = $varQS;
anonymous
Thanks, Jason. That worked. Hope you have a nice weekend!
