HTTP Error Code 404
Thread began 6/29/2013 11:18 am by elevy388997 | Last modified 7/15/2013 10:22 am by Jason Byrnes | 7949 views | 18 replies |
elevy388997Beta Tester
HTTP Error Code 404
I am trying to connect to a database to use PowerCMS in order to add sections to the CMS. I have 2 databases connected through dreamweaver but now I get errors. I don't know what changed. What I do know is that the MMHTTPDB.php file is not in the testing server or remote server at all. When I first connected through dreamweaver to see the tables (maybe 20 minutes ago) I got in, but then I went to add an area to the CMS and I can't get into anything anymore. Even if I put "w" for the username and password, it gives me the 404. So it doesn't even get to the point of trying the login.
The _mmServerScripts folder has 777 permissions. I even found a copy of the file and uploaded it myself and my testing server deletes it...but leaves the main _mmServerScripts folder there.
Remote:
root dir: /public_html/
web url: http://www.williamsportwomenstennisleague.com/
connection: FTP
(connects fine)
Testing:
server Folder: G:\xampp\htdocs\WWTL\
web url: http://localhost/WWTL/
connection: Local/Network
(Xampp is up and running)
Thanks!
UPDATE: I found this - http://forums.adobe.com/message/5436661 -
"Apparently, the problem is that the MMHTTPDB.php and mysql.php files are not copied to the Connection folder. The user need to do that him/herself. The two files are found in Users/*username/Library/Application Support/Adobe/Dreamweaver CC/*language/Configuration/Connections/Scripts/PHP_MySQL. Btw, that is a new path to their location, so advices on where to find them in earlier versions of DW do not work with CC."
But my file was located at Users/*username/AppData/Roaming/Adobe/Dreamweaver CC/en_US/configuration/Connections/Scripts/PHP_MySQL/_mmDBScripts
Now when I copied that into the local file and uploaded it I can get into my localhost database using the root username and password. Now how do I get it to access the remote server and upload to the appropriate databases?
When I put in the Remote database info, I get "MySQL Error#: 2002 A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
I've looked all this up and I tried turning off anti-virus, adding 127.0.0.1 localhost to the hosts file, adding my ip in the remote access portion of mysql...
So right now I have local testing server database connection and functionality, but my remote database connection gives me that MySQL Error#2002: .
Just in case, the info I am using to connect to the remote database is:
Server: FTP address
Username: MySQL username
Password: MySQL password
Sorry that I am so random, as I have further problems or what not I add it to my post.
Through all of that I ended up applying for a firewall exception with my hosting company and used their live chat feature to have them attend to it right away. All is working now!
Hopefully that bit of DW CC path information helps someone.
After letting the whole situation difuse in my head, I came back, opened dreamweaver and tried to add a section to the CMS and I get the same error about the _mmServerScripts File. DW seems to be deleting it from my local source when I try to make a connection...
here is an updated copy of the Configuration/Shared/Library/WA_database.js file that should correct the problem.
it should be copied to the location in the users configuration folder mentined above. For help finding the users configuration fodler, see the following page:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
WA_Database.js.zip
I replaced that .js file and copied a new MMHTTPDB.php into the _mmServerScripts folder, uploaded it and now I get HTTP Error Code 500 Internal Server Error. This happens after I input the database connection info and click select. I also tried just entering in the server and then fake username and password and I still get the error, so it is happening before it actually tries the login info.
if you edit the connection and use the test button what happens?
if it gives the same error, that would men there is a problem with the site definition settings, specifically the testing server settings.
I do not have any connections setup anymore so I am still in the process of creating one. And if I push test it prompts me to select a database first. Now if I change my testing server URL from http://localhost/site to http://www.site.com I get "An unidentifed error has occured."
So that points to the prefix for the testing server URL. The website itself is www.williamsportwomenstennisleague.com and on my end I call it WWTL.
Testing server
Server Name: Local
Connect using: Local/Network
Server Folder: G:\xampp\htdocs\WWTL\
Web URL: http://localhost/WWTL/ and i've also tried the actual site url.
When you change the testing server URL, you also need to change the connection settings to use FTP, to connect to the remote server
Couldn't I just check the box for "testing server" on my current remote connection?
Yes, that should work.
