Adapt eCart to process WorldPay transactions Locally
How can i adapt Ecart to process Worlpay transactions locally rather than remotly.
Within eCart only the remote payments are supported with Worldpay. To integrate a local checkout for use with Worldpay would require a custom implementation of this service. If you are interested in performing this type of integration your merchant gateway must first support the technique, then it must be developed for use on your site with their system. This usually requires a bit of development work using the provided developer resources from the gateway.
Worldpay will provide a stater XML script for me to work on but they can't / don't provide the form to capture the data. Worldpay also require a PCI certificate to operate the payment locally.
Your form should be based on the sample xml script they gave you. The form will need to gather all the required values that are needed by the script.
You can then use the references to these fields in your script to process the transaction. For the PCI compliance you will need to check with vendors that offer this type of certification. Here is a link to the PCI site that gives all the information and details you should need:
www.pcisecuritystandards.org/
