Framework theme half works
Okay. So I have a template that has been converted to a theme. If I open a page with that template and apply the theme I get a message saying "The template that this document is based on does not allow changes outside of the <html> tag. The change you made will be discarded". And then the code for the theme does not make it into the document (just a blank doc with the template applied). However, if I use the Create Page with Theme, I see the template name and it works fine.
