admin login not working for none super admin
ive created a new user and password login is correct but not working
here is the site
http://sugarbakerscc.com/admin_cms/users_login.php
here is the site
here is the info in private message
on the users login page, the following lines:
"columns" => explode($WA_Auth_Separator,"UserEmail".$WA_Auth_Separator."UserPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["userName"]))?$_POST["userName"]:"") ."".$WA_Auth_Separator."".((isset($_POST["Password"]))?$_POST["Password"]:"") .""),
had been changed to:
"columns" => explode($WA_Auth_Separator,"UserEmail".$WA_Auth_Separator."UserPassword".$WA_Auth_Separator."UserID"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["userName"]))?$_POST["userName"]:"") ."".$WA_Auth_Separator."".((isset($_POST["Password"]))?$_POST["Password"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userName"]))?$_POST["userName"]:"") .""),
i changed those lines back and the login is functioning now.
thank you what could have changed the lines
no idea, I was not present when the change happened.
all i can tell you is that they where changed and the change caused the problem.
