PS3, eCart 4.5, DW CS6
Thread began 6/17/2013 4:32 pm by mick106153 | Last modified 6/18/2013 11:03 am by mick106153 | 407 views | 6 replies |
mick106153
I have a PS3 site and want to add some discounts but it seems eCart 4.5.2 doesn't want to play. If I upgrade to the latest eCart what teething problems can I expect using it with PS3 and DW CS6 on a Mac?
In Power Store 3, you can add Discounts in the Admin section.
in the Power Store admin, go to the Coupon / Sales tab to configure discounts.
mick106153
OK Will do, but what is the answer to my previous question?
eCart 5 is compatible with Dreamweaver CS6.
mick106153
Thanks Jason and it should play well with PS3? Contemplating a need for more complex discount scenarios.
Power Store 3 was built with eCart 4. eCart 5 can be used to modify eCart 4.
that being said, there is a lot of custom coding that when into Power Store. eCart was used as the Basis with custom coding added to accomplish some features.
It is posible that editing the eCart object using eCart 5 may break some of that custom code. Modifying the cart using eCart is not supported in Power Store.
mick106153
Thank you Jason
