Databridge
Thread begun 6/16/2013 12:17 am by gerry164083 | Last modified 6/18/2013 7:33 am by Jason Byrnes | 1461 views | 3 replies |
gerry164083
Databridge
Using DW4
just bought databridge.
un-installed all other extensions
Installed Databridge
Activates OK
Trying to run either dataassist or security assist cause freezes after bring blank file activity dialogue (see attached screen grab)
Tried deleting wincache file and re-installing no different
Other bits of the extension I tried seem to work
doesnt look like it can make a connection to the testing server.
in the files panel, change from Local View to Testing Server view, see if that forces the testing server conecton.
in the site settings, how is the testing server deefined?
ate you using an FTP conenction to the testing server?
Make sure the Web URL is set correctly, and double check the root directory, in some instances, you may need to specify /htdocs or another root directory so the connection is made to the site root.
gerry164083
Resolved
The site I was working on was protected by .htaccess as it is under deverlopment.
When the exyension / dreamweaver faced being asked for a login it didn't know what to do so hung.
Works on an open site.
glad to hear you found the problem.
