dynamic data not sent in email
Thread begun 6/14/2013 12:40 pm by Ashok | Last modified 6/14/2013 2:15 pm by Ashok | 3508 views | 12 replies |
Ashok
I have a forgot password page. The logic is:
1. The form is submitted.
2. Data retrieved from db.
3. Dynamic data inserted in email body.
4. Email send.
I have tried http://www.webassist.com/forums/posts.php?id=17869 but just get letter "a" in dynamic fields.
Is it possible that the email triggers before the recordset?
What is the correct trigger in this case?
send a copy of your page and the email template.
Ashok
Here is the page and template.
since you are not using a template file to manage the email, you don't need to use the $RecipArray[$RecipIndex][0]['name']; syntax, you can use the standard $row__recoverpassword['name'] syntax instead.
Ashok
In this case the dynamic data is missing in the email. It seems first the email is triggered and then data retrieved in recordset. Is this possible?
the recordset is set to use the form element named email for filtering, but the text box on your page is named txtemail
Ashok
Yep I noticed that and corrected.
Now the TO field gets data from recordset and email is sent.
But the dynamic data in email body is empty.
$MailBody = $MailBody . "<p>????????????, ";
$MailBody = $MailBody . $row__recoverpassword['name'];
May be I need to echo $row__recoverpassword['name']; ?
Ashok
sent
Originally Said By: Ashok
  sent
