div overlay
Thread begun 6/13/2013 11:22 am by randyw2394710 | Last modified 6/13/2013 1:09 pm by Jason Byrnes | 1427 views | 3 replies |
randyw2394710
div overlay
im trying to create div overlay.
when the displayblock:none, is set to display, the div apear fine. so my css and require once is fine, i assume its the java
THE JAVA
$('Unsubscribe-overlay').addEvent('click', function() {
$('overlay-bg').setStyle('display', 'block');
$('overlay-Unsubscribe').setStyle('display', 'block');
$('overlay-popup').setStyle('display', 'block');
return false;
THE LINK
<a href="#" title="Unsubscribe" name="Unsubscribe" id="Unsubscribe-overlay">Unsubscribe</a>
THE DIV TO DISPLAY
<div id="overlay-bg"></div>
<div id="overlay-Unsubscribe" class="overlay-popup">
i would need to see the probelm in the web browser in order to troubleshoot.
randyw2394710
http://sugarbakerscc.com/
at the end of the page there is unsubscribe link
your mixing moo tools syntax with jquery. The code on your page uses the moo tools syntax, but you don't include moo tools.
see this tutorial for a simple popup window using jquiery:
http://blog.theonlytutorials.com/a-very-simple-jquery-popup-ready-to-use-code/
