Warning: Cannot modify header information - headers already sent
Thread begun 6/05/2013 11:24 am by tom92909 | Last modified 9/16/2015 11:10 pm by Ray Borduin | 11637 views | 4 replies |
tom92909Beta Tester
I'm using my new Data Bridge v.1.1.3 to create a contact form. The form wizard was very simple to use. The end result was that I have a functional form that sends a message as expected, but I'm getting an error on the redirect. The successful message sent is supposed to route to a thanks.php page but instead of doing that it provides an error
Warning: Cannot modify header information - headers already sent ... /webassist/form_validations/wavt_scripts_php.php on line 84
I was getting session (3) errors earlier; Warning: session_start() [function.session-start]: Cannot send session cache limiter
But I added the following to the bottom of the page which has resulted in the error related to the wavt_scripts_php.php page.
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
@session_regenerate_id();
what is the full error?
the middle of the error will contain a section that says:
output started:.......:<line number>
the page listed in the output and the line number is the cause of the problem.
send the full error and the page listed in the output.
tom92909Beta Tester
The following are the full error messages:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/demo/public_html/dev2/contact.php:1) in /home/demo/public_html/dev2/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/demo/public_html/dev2/contact.php:1) in /home/demo/public_html/dev2/webassist/email/mail_php.php on line 274
Warning: Cannot modify header information - headers already sent by (output started at /home/demo/public_html/dev2/contact.php:1) in /home/demo/public_html/dev2/contact.php on line 148
The error message after I added the destroy session code after the </HTML> tag.
Warning: Cannot modify header information - headers already sent by (output started at /home/demo/public_html/dev2/contact.php:1) in /home/demo/public_html/dev2/webassist/form_validations/wavt_scripts_php.php on line 84
the output is being reported at line 1.
this happens for 2 reasons:
1) The BOM Signature is enabled.
in DW go to:
Modify -> Page Properties
in the Title / Encoding Section, make sure the option to Include the Unicode (BOM) Signature is not checked.
2)There is a blank line or other HTML at line 1.
Eliecer
Thank you so much!
