PowerCMS Installation Wizard
After creating a website with PowerCMS uploaded the site to server, it does not install after I Press the Get Started Button.
http://www.parroquiasanesteban.org/beta5/install_cms/index.php
Most likely, there is a problem with session management on the server.
use the attached sessionTest.php page to test for session management. If the session text fails, it is most likely the session.save_path setting in the php.ini file, you will need to contact the host to have them correct the problem
