powerstore not loading
hi there, I cant access the shop admin or visit the shop.
http://www.smart-fx-uk.com/shop/admin
on trying to access the shop i get the following error:
Access denied for user 'smartfx'@'192.168.0.15' (using password: YES)
this means that the settings you used in the /shop/Connections/PowerStoreConnection.php file are not correct for accessing the MySQL Server, you will need to edit that file with the correct details to make the connection.
Ah ok
Is there anyway of reinstalling the shop without losing all the products, I accidently deleted my previous database!!
The products where stored in the database, by deleting the database, you also deleted the products,
Ok,
Damn I am an idiot!!!!
Anyway I've re-installed everything and getting the HTTP 500 error message upon accessing the admin.
there was a missing file in the webassist/themes/Default/images folder causing the problem.
hi, for some reason I cannot upload images in the design settings section, as the browse option is not visible and no images are showing?
