Data Assist and Drop-Down Fields
When using Data Assist to create pages that pull information from a MySQL database, is there a way to have drop-down fields in the update page?
Yes, in the configure fields settings on the manage pages tab, you can set a field to display as a menu, and click the lightning bolt icon to select the table that should be used to populate the menu.
