Add Multiple Items to cart
Thread began 5/23/2013 9:15 am by steve150290 | Last modified 5/23/2013 11:59 am by steve150290 | 629 views | 2 replies |
steve150290
Have a need to set up a conference registration area, need to require the conference registration with a few fill in questions (name, badge title etc), also need to be able to select additional options, like lucheons, dinners, classes etc, thinking to allow them to be selected by a check box, then have a single add to cart to lock all the info into the database and proceed to a payment checkout. I have ecart but can I do this with powerstore as a way to save some development time? I have attached a pdf of an example. Thanks
You could use the Advanced Options of Power store to accomplish this.
It can also be done in eCart.
for each option, you would need to add a column to the eCart object.
In the add to cart button, set the option column to updatable.
steve150290
Thank You!
