My CSS Menu Writer was working fine until I installed Design Extender. Now when I create a new menu or modify an existing menu I get the following error message. "Parse error: syntax error, unexpected T-String, expecting T-OLD-FUNCTION or T-FUNCTIO
Thread begun 5/23/2013 8:11 am by ovknox388992 | Last modified 5/23/2013 11:34 pm by ovknox388992 | 1462 views | 2 replies |
ovknox388992
CSS Menu Writer stopped working properly when I installed Design Extender.
My CSS Menu Writer was working fine until I installed Design Extender. Now when I create a new menu or modify an existing menu I get the following error message. "Parse error: syntax error, unexpected T-String, expecting T-OLD-FUNCTION or T-FUNCTION or T-VAR or ' } ' in /homepages/19/d318199560/htdocs/mywebsite_html/webassist/framework/framework.php on line 3. How can I correct this problem?
What version of PHP is running on the server?
Design Extender requires PHP version 5.2 or higher. The error suggests that the php version on the server is php 4.x, you should be able to have the host upgrade the PHP version on the server fairly easily. Most hosts have an option in the sites control panel to change the PHP Version.
ovknox388992
My apologies...disregard my previous message. I was confusing MySQL and PHP. My issues is resolved. 1and1 does support PHP versions up to 5.4. Thanks for your patience with newbees like me.
