Plug-in not working, blank page
Thread began 5/22/2013 4:39 am by YellowCircleWeb | Last modified 5/22/2013 11:36 am by Jason Byrnes | 1416 views | 3 replies |
YellowCircleWeb
I'm trying to use a DataAssist results page as a plug-in. Basically the page retrieves records from a recordset and displays them in a table.
When I run the page with the plug-in added I get a blank page indicating a PHP error somewhere. I've used similar plug-ins on the site I'm developing and they worked first time. I haven't changed the procedure this time in how I created the dataassist page or added the plug-in.
I've attached both the dashboard page file and the plug-in file in the zip. In my site structure the admin-dashboard page is in a directory called admin and the plug-in file is in a directory called plug-ins, but I've just put both files in the zip together here.
admin-dashboard-plugin.zip
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
YellowCircleWeb
Thanks for the reply Jason. I have fixed the error myself now. It was a syntax error due to the way I had named my view in the database.
Cool, glad to hear it is working.
