insert behavious give '0' value instead of text
Thread begun 5/22/2013 12:15 am by Sweens | Last modified 5/22/2013 9:45 am by Jason Byrnes | 2115 views | 5 replies |
Sweens
Hi
I have an insert page that, after insert, redirects to the update page. Everything works OK EXCEPT a '0' is inserted instead of the title text. I've looked everywhere and can't see what's going wrong! All other fields have the proper values.
I've checked in the database and a zero has been inserted there, so it's not the update page at fault!
Attached is the insert code.
Any help much appreciated, as always
Chris
NOTE: When sending an attachment, please include the entire page, not just the code for the insert. I need to see the entire page with the insert code in context. It is much more helpful if you compress the insert page to a zip archive and attach the zip file rather than copy just the insert code to a text file.
Sweens
Hi Jason
Many thanks - sorry just to post the insert part - thought it would make things easier!
Private message below
I dont see an obvious problem in the code.
Sweens
Originally Said By: Sweens
