Create DataAssist pages
Delete button doesn't work on results or details page, there is no back button on the update page, there is no search reset button on the results page and why is there a top button on the details page?
[QUOTE=151934;Bart Banks]Delete button doesn't work on results or details page,
Delete Send a copy of the Details and Results page please so i can see the code
This is by design.
you can add one by copying the back to results button from the details page. I will log a request to have this added to the update page.
There is a link to go to the search page to start a new search. Starting a new search will reset the search.
If you have a long liist of columns on the details page, the top button will reset the page to the top.
I removed the delete button from the results page, but if you figure out what the problem with the details delete button is, it's probably the same problem on the results page.
It looks like the column in your table that is set to be the ID column, ecm, is a text column.
the ID column for the table should be a numeric column, it should be set to auto increment so that each record created gets a unique id number.
The id colomn in my table is set to integer auto inc.
In the delete record behavior, the Data Type for the Key Column value is set to text.
open the server behaviors panel, and double click the Delete Record server behavior to edit it and change the Data Type for the Key Column to Integer.
There is no option to change the data type in the delete server behavior
It's on our intranet
