Inserting quotes into a field
Thread begun 5/09/2013 2:52 pm by eric284736 | Last modified 5/15/2013 6:34 pm by eric284736 | 768 views | 2 replies |
eric284736
Hi Jason,
I am trying to insert size info into a field (example: 36"x12"). When I go to update the page it removes part of the size info so it shows only 36.
Do I need to encode the data being inserted? The data field type is text.
thx
Eric
yes, the quotes should be converted to html entities
you can do this using the following code on the line 1 of the insert and update pages:
if(!empty($_POST)) {
    foreach(
$_POST as $key => $value) {
$_POST[$key] = str_replace("\"""&quot;"$value);
eric284736
Thanks Jason!!!!
