Making option fields required
http://zoeringdesigns.com/products_detail.php?ProductID=1
How can I make these option fields required? I don't see a way to do this in the admin area. Thank you!
Power store does not have validation for options fields.
the best bet is to set the default value of the options to a valid option value forcing the customer to change it.
That's just it - there won't be a default option. For the type of information she's capturing, every entry will probably be different. I need the descriptive text there so people know what to enter. I'll have to see if I can come up with something. Thanks.
