conditional form field display
Thread begun 5/02/2013 2:17 pm by Steve430995 | Last modified 5/03/2013 7:00 am by Jason Byrnes | 777 views | 1 replies |
Steve430995
I see that data bridge has a form tool of some sort in it- can you tell me does it support the conditional display of fields.
I'm working on an order form that will need to display different fields depending on the choice of one of 4 initial products ( could be chcknoxes) and then display in a drop down only 4 of 16 sub skus again dependent on the initial selection of one of the 4 products
No, form Builder does not support conditional display of form fields, you would need to hand code a java script function to show or hide the form fields based on the selection.
