Multiple insert not working
I have a repeat table inside a form. After submit it should update the database, but nothing is entered. I have no idea where to look for the problem.
I have included the page and the table view of SQL 2008 table
Thanks for including the page, that is very helpful. When I look at your page I can see that there is a part that is not rite. In your multiple insert at the top you have the looped fields specified. The way they are specified is not correct and will cause the insert to not occur correctly.
What is the version of DataAssist that you have installed that you are using for this? Also what steps did you take to make this insert page a multiple insert?
I did a quick test to compare to yours and got a positive result with my test. Here is what I did to get it configured correctly.
First I had a page with a simple form on it. I then applied the DataAssist repeat selection to the rows of the form that I wanted to include for each record I insert. Next I just went to the DataAssist > Insert > Multiple Insert. From here I selected 'always insert' then the connection, the table and the redirect page. On the next step I selected the column in the db, then for the value I used the lightning bolt to select the corresponding form field. When I finished I had a working multiple insert.
Please post back with some details about what you are doing in the wizard and the version you are using so we can see if there is some issue there.
I use WADataAssist205
My steps
I first make the table inside a form.
Make sure it was working
Then applied the repeat selection.
Then I selected multi Insert from DataAssist and use the dropdown to select to appropiate colums where to insert
When running the page again I get an string error from the WA_loopedFields
The problem was the last %> in every record added so I changed this to &premil;> then it worked okay but nothing was inserted into the database.
I tryed to make a insert page with dataAssist
Very simple insert.
But it will not work, i get an error
Microsoft OLE DB Provider for SQL Server error '80040e14'
Incorrect syntax near '34'.
/DressForm_Insert.asp, line 31
' WA Application Builder Insert
if (cStr(Request.Form("Insert.x")) <> "") then
WA_connection = MM_vbOFM_STRING
WA_table = "dbo.DressForm"
WA_sessionName = "WADA_Insert_dboDressForm"
WA_redirectURL = "DressForm_Results.asp"
WA_keepQueryString = true
WA_indexField = "MeasuementID"
WA_fieldNamesStr = "ContactpersoonId|Number|Name|34|Grading1|36|Grading2|38|Grading3|40|Grading4|42|Grading5|44|Grading6|46|Grading7"
WA_fieldValuesStr = "" & cStr(cStr(Request.Form("ContactpersoonId"))) & "" & "|" & "" & cStr(cStr(Request.Form("Number"))) & "" & "|" & "" & cStr(cStr(Request.Form("Name"))) & "" & "|" & "" & cStr(cStr(Request.Form("34"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading1"))) & "" & "|" & "" & cStr(cStr(Request.Form("36"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading2"))) & "" & "|" & "" & cStr(cStr(Request.Form("38"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading3"))) & "" & "|" & "" & cStr(cStr(Request.Form("40"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading4"))) & "" & "|" & "" & cStr(cStr(Request.Form("42"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading5"))) & "" & "|" & "" & cStr(cStr(Request.Form("44"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading6"))) & "" & "|" & "" & cStr(cStr(Request.Form("46"))) & "" & "|" & "" & cStr(cStr(Request.Form("Grading7"))) & ""
WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL"
WA_comparisonStr = " = | = | LIKE | = | = | = | = | = | = | = | = | = | = | = | = | = | = "
WA_fieldNames = Split(WA_fieldNamesStr,"|")
WA_fieldValues = Split(WA_fieldValuesStr,"|")
WA_columns = Split(WA_columnTypesStr,"|")
WA_comparisions = Split(WA_comparisonStr, "|")
insertParamsObj = WA_AB_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, -1)
set MM_editCmd = Server.CreateObject("ADODB.Command")
MM_editCmd.ActiveConnection = WA_connection
MM_editCmd.CommandText = "INSERT INTO " & WA_table & " (" & insertParamsObj(1) & ") VALUES (" & insertParamsObj(2) & ")"
MM_editCmd.Execute()
MM_editCmd.ActiveConnection.Close()
obj = WA_AB_generateWhereClause(WA_fieldNames, WA_columns, WA_fieldValues, WA_comparisions)
sqlstr = "SELECT " & WA_indexField & " FROM " & WA_table & " WHERE " & obj & " ORDER BY " & WA_indexField & " DESC"
set WA_AppBuilderRecordset = Server.CreateObject("ADODB.Recordset")
WA_AppBuilderRecordset.ActiveConnection = WA_connection
WA_AppBuilderRecordset.Source = sqlstr
WA_AppBuilderRecordset.CursorType = 0
WA_AppBuilderRecordset.CursorLocation = 2
WA_AppBuilderRecordset.LockType = 1
WA_AppBuilderRecordset.Open()
if (NOT WA_AppBuilderRecordset.EOF) then Session(WA_sessionName) = WA_AppBuilderRecordset.Fields.Item(WA_indexField).Value
WA_AppBuilderRecordset.Close()
if (WA_redirectURL <> "") then
if (WA_keepQueryString AND Request.QueryString <> "" AND Request.QueryString.Count > 0) then
if (inStr(WA_redirectURL,"?") > 0) then
WA_redirectURL = WA_redirectURL & "&"
else
WA_redirectURL = WA_redirectURL & "?"
end if
WA_redirectURL = WA_redirectURL & Request.QueryString
end if
Response.Redirect(WA_redirectURL)
end if
end if
So then I tryed the wizard from dreamweaver and also the same simple form
This one works perfectly
If (CStr(Request("MM_insert")) = "form1") Then
If (Not MM_abortEdit) Then
' execute the insert
Dim MM_editCmd
for i=0 to 4 step 1
Set MM_editCmd = Server.CreateObject ("ADODB.Command")
MM_editCmd.ActiveConnection = MM_vbOFM_STRING
MM_editCmd.CommandText = "INSERT INTO dbo.DressForm (ContactpersoonId, [Number], Name, [34], Grading1, [36], Grading2, [38], Grading3, [40], Grading4, [42], Grading5, [44], Grading6, [46], Grading7) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)"
MM_editCmd.Prepared = true
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param1", 5, 1, -1, MM_IIF(Request.Form("ContactpersoonId"), Request.Form("ContactpersoonId"), null)) ' adDouble
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param2", 5, 1, -1, MM_IIF(Request.Form("Number"), Request.Form("Number"), null)) ' adDouble
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param3", 202, 1, 200, Request.Form("Name")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param4", 202, 1, 10, Request.Form("Element")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param5", 202, 1, 10, Request.Form("Grading1")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param6", 202, 1, 10, Request.Form("Element2")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param7", 202, 1, 10, Request.Form("Grading2")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param8", 202, 1, 10, Request.Form("Element3")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param9", 202, 1, 10, Request.Form("Grading3")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param10", 202, 1, 10, Request.Form("0")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param11", 202, 1, 10, Request.Form("Grading4")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param12", 202, 1, 10, Request.Form("Element4")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param13", 202, 1, 10, Request.Form("Grading5")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param14", 202, 1, 10, Request.Form("Element5")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param15", 202, 1, 10, Request.Form("Grading6")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param16", 202, 1, 10, Request.Form("Element6")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param17", 202, 1, 10, Request.Form("Grading7")) ' adVarWChar
MM_editCmd.Execute
next
' append the query string to the redirect URL
Dim MM_editRedirectUrl
MM_editRedirectUrl = "Results.asp"
If (Request.QueryString <> "") Then
If (InStr(1, MM_editRedirectUrl, "?", vbTextCompare) = 0) Then
MM_editRedirectUrl = MM_editRedirectUrl & "?" & Request.QueryString
Else
MM_editRedirectUrl = MM_editRedirectUrl & "&" & Request.QueryString
End If
End If
Response.Redirect(MM_editRedirectUrl)
End If
End If
I am using sql 2008 and this script works perfect
INSERT INTO
dbo.DressForm
( ContactpersoonId, Number, [Name], [34], Grading1, [36], Grading2, [38], Grading3,
VALUES (3,0,'Test1',1,2,1,0.5,12,2,100,4,104,2.25,106.25,2,108.25,0.75),
(3,1,'Test2',1,2,1,0.5,12,2,100,4,104,2.25,106.25,2,108.25,0.75),
(3,2,'Test3',1,2,1,0.5,12,2,100,4,104,2.25,106.25,2,108.25,0.75);
The problem is I need to replace the values with a variable so I can use the form that I have and insert mutliple records using a loop but what ever I try have no luck so far.
I have opened a ticket for you other thread: showthread.php?p=12960#post12960
Please do not respond to this thread.
