Digital File Pro is still a part of Data Bridge.
you can access Digtial File Pro upload by going to Webassist -> File Manipulation -> Upload.
create the form with the file field, then add the Digital File pro upload behavior to upload the PDF File, then add the Data Assist Insert Record behavior. Open the server behaviors panel, click the plus button and select WebAssist -> Data Assist -> Insert -> Single record Insert.
in the insert behavior, select the connection and the table to use.
on the bindings tab, bind each column to the corresponding form element. Select a column, then click the lighting bolt next to value and select the form element from the bindings list.
for the file field, use the WA Uplloaded Files -> Server File Name binding
