Add CMS to fluid grid design
Thread began 4/19/2013 1:22 pm by elevy388997 | Last modified 4/19/2013 1:49 pm by elevy388997 | 934 views | 2 replies |
elevy388997Beta Tester
I am making a fluid grid design for a client and now they want a CMS. How would I go in and set each section to be a certain CMS editable area? Will the menu link Webassist > CMS > Add content to CMS (or something like that) be what I want to use? Will it also generate the admin area as if I created a site using site sculptor?
If you generate the site using site sculptor, there is an option in site sculptor to add CMS to the site, on the page settings, you select which section should be CMS Driven.
if you have already generated the site, then yes, use the Webassist > CMS > Add content to CMS menu item to convert a page content to CMS Content.
Either way, the CMS Will add the admin section also.
Perfect. Just wanted to make sure I was on the right track. Thanks as always!
