Include the id of each email in the body of the message and the log table
Thread began 4/19/2013 10:39 am by edu311178 | Last modified 4/19/2013 1:17 pm by Jason Byrnes | 746 views | 3 replies |
edu311178
Hi I'm using Data bridge to create a massive email sending. I would like to include the name of each recipient in the body of the email. I tried to use these code
<? php
RecipArray global $;
RecipIndex global $;
But does not work. What exactly is the page I have to put the code? The page where I created the form "fss_mailing_enviar.php" or databrige page generated inside the email folder "waue_fss_mailing_enviar_2.php"?
And where I have to put the php variable with the id and name of each record individually?
<?php echo($RecipArray[$RecipIndex][0]["[yourColumnName]"]); ?>
in my case the fields are called "id" and "name"
thanks a lot
In universal Email, did you select the option to create a file to manage the email message?
if so there is a template file for the email in the webassist/email/templates folder, the code should be added in that template file.
edu311178
I'm using a site created with dreamweaver. Is it the same code? and secondly how do I keep this data in the log table? What is the value that I have to use? I'm using the default table created by the application
the fact that it is a Dreamweaver site does not tell me the settings you used when adding Universal email to it.
in the Universal Email wizard, did you select the option to create a file to manage the email?
if so, a template files is created in the webassist/email/tempaltes folder. the code goes in that template file.
the log will save the email body. anything included in the email body will be saved in the log.
