SecurityAssist Show Region (Logged in to users) (prior version)
I used SecurityAssist to create my Registration and Admin pages. I uploaded all of my Registration pages to my host. I updated the database with new fields and new users. I attempted to log in with my username and password and all worked as expected. Yay!
I then tried to add a new user. I wanted to make sure that process was working properly. Oops. Problem. When I click on the verify link in the Registration email I get the following error message:
Fatal error: Call to undefined function wa_auth_rulepasses() in /home/maysbw/public_html/protected/user-confirm.php on line 168
When I go to line 168 in user-confirm.php the following code is present:
<?php if(WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<a href="login_success.php"><img src="../images/template_images/bw_green_go_back_inside.gif" width="100" height="50" alt="New User Button" /></a>
<?php } // End Show Region ?>
I was going to double click the Server Behavior when I noticed the following in the Server Behaviors panel list:
SecurityAssist Show Region (Not logged in to users) (prior version)
I thought if I double clicked the server behavior I might be able to clear out that "prior version" nonsense. I double clicked and all looked to be as it should be. So I clicked OK and got the following error message:
While executing applyServerBehavior in ShowRegion.htm, a JavaScript error occurred.
I checked all the other protected pages and none have this prior version problem. I'm not sure if this is relevant, but when I started the process of creating these .php pages I decided to change all the pages from .html to .php with login/logout/register buttons on every page. Could this be the reason the verify email isn't working?
Please advise.
