Chart Width
Thread begun 4/16/2013 8:32 am by sysop349733 | Last modified 4/17/2013 7:42 am by Jason Byrnes | 1845 views | 3 replies |
sysop349733
Chart Width
Changing the chart width in the wizard or in the page's html is having no effect on the appearance of the chart.
Attached is an actual size of a chart with width = 800. I have tried other widths too, with no effect.
How can I make the chart wider to accommodate the data?
sysop349733
Apparently the width is set twice. The wizard will update the width attribute for the IE Flash object, but not the width attribute for the non-IE Flash object. Editing that by had will display the chart properly in Firefox and Chrome.
Thank you for reporting this issue, i have logged the problem in our bugbase to corrected in an update.
