PowerGallery V2 Installation Step 4: Create admin login
Thread begun 4/13/2013 6:39 am by wr435294 | Last modified 4/18/2013 6:47 am by Jason Byrnes | 1904 views | 4 replies |
wr435294
Hello,
I am trying to install PG V2, just purchased it, but I got an error which says "ERROR: Failed to save the settings in the database. Please verify your database connection." I checked my connection, and everything seem to be correct; I even add a fake password to make sure I am connected to the database and this is what it says "Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'gallery'@'cgi1803.int.bizland.net' (using password: YES) in /hermes/waloraweb083/b1902/moo.walkerrcom/site/gallery/Connections/powergallery.php on line 9
Fatal error: Access denied for user 'gallery'@'cgi1803.int.bizland.net' (using password: YES) in /hermes/waloraweb083/b1902/moo.walkerrcom/site/gallery/Connections/powergallery.php on line 9," so I created a new password and the was fixed, which in turn confirms that my database connection is correct. I am stuck on step 4 of the installation process and don't know what or where issue lies.... HELP PLEASE!!!
Thank you.
Did the tables get created in the database properly? using phpMyAdmin or another GUI tool to access the database, make sure that the gallery tables are created, if they are not, you can use the Import tab in phpMyADmin, and use the install_gallery/scripts/db.sql file to create the tables.
wr435294
I import "db.sql," but it is still not allowing me to go beyond step 4. Any other idea, please?
I'll have to look into this issue with you.
See the private message section
