Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource/webassist/form_validations/wavt_scripts_php.php on line 642
Thread began 4/12/2013 11:53 am by David | Last modified 4/15/2013 12:08 pm by Jason Byrnes | 3907 views | 4 replies |
David
HI
I keep getiing these warnings after I fill in the registration form set up by security assist. Everything is Ok in local host but this happens on the remote server
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/rolypoly/public_html/performadvance.com/htdocs/webassist/form_validations/wavt_scripts_php.php on line 642
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/rolypoly/public_html/performadvance.com/htdocs/webassist/form_validations/wavt_scripts_php.php on line 645
These are lines 642-645 inclusive
mysql_select_db($db, $conn);
$WA_UniqueWhere = Validations_generateWhereClause(array($filterCol, $keyCol), array($filterType, $keyType), array($filterValue, $keyValue), array("=", "<>"));
$WA_UniqueSQL = "SELECT `".$keyCol."` FROM `".$tableName."` WHERE ".$WA_UniqueWhere->sqlWhereClause;
$WA_UniqueRS = mysql_query($WA_UniqueSQL, $conn) or die(mysql_error());
Thanking you in anticipation
Before uploading the pages to the live server, you need to edit the Database connection file with the correct details for connecting to the MySQL Server on the Host.
David
Hi Jason
I think I have already done that. I changed the details from
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_connPerform = "localhost";
$database_connPerform = "perform_advance";
$username_connPerform = "root";
$password_connPerform = "";
$connPerform = mysql_pconnect($hostname_connPerform, $username_connPerform, $password_connPerform) or trigger_error(mysql_error(),E_USER_ERROR);
to
$dbh=mysql_connect ("localhost", "cpuser_dbuser", "password") or die ('I cannot connect to the database because: ' . mysql_error());
mysql_select_db ("cpuser_db");
This works until I want to submit the data when I get the above warnings
Thank you
Dont change the code completely as you have done.
only change the values being used in the connection code.
change:
# Type="MYSQL"
# HTTP="true"
$hostname_connPerform "localhost";
$database_connPerform "perform_advance";
$username_connPerform "root";
$password_connPerform "";
$connPerform mysql_pconnect($hostname_connPerform$username_connPerform$password_connPerform) or trigger_error(mysql_error(),E_USER_ERROR);
# Type="MYSQL"
# HTTP="true"
$database_connPerform "cpuser_db";
$username_connPerform "cpuser_dbuser";
$password_connPerform "password";
by changing the code the way you did, you changed the variable names that the code is generated to use. only change the variable values.
