Datepicker / validated fields
Thread begun 4/10/2013 5:37 am by Banksie | Last modified 4/10/2013 8:22 am by Banksie | 1281 views | 3 replies |
Banksie
I have a form including 2 datepicker fields (for a start and end date of a reservation period; datepicker_1 allows choice of dates from today onwards - datepicker_2 allows choice of dates from the selected datepicker_1 value onwards). On submission the entire form is validated and, if validation fails, the form is re-presented for correction. All validated field values are populated as you'd expect from the WAFV_Conditional values - except the datepicker fields.
How to I set the initial value of the datepicker fields (assuming they're validated) to the WAFV validated field value when the whole form is displayed, say, for other invalid fields to be corrected?
I know how to set the initial date, for instance, to be today (so earlier dates are not selected):
dateFormat: 'D, d M, yy', minDate: 0,
but can't figure out how to set the date, after validation, to a validated field being returned with all other WAFV_Conditional values.
you need to use split view so you can access the code.
in the design side, select the date picker element.
On the code side, it will show the datae picker element code, there is a value attribute:
value=""
place your cursor between the quotes, and go to the bindings panel. In the bindings panel, expand the validated entries collection, select the corresponding element and click the bind button, this will add the validated entries binding code to the value attribute of the date picker element.
Banksie
Many thanks (as usual) Jason. Should've been obvious to me - thought the value had to be set in the javascript initialisation and not in the field value (incidently - I had to add the "value" attribute by hand - it wasn't there in the field properties by default. No problem, just a point to note)
Cheers
Gary
