display number of occurrences of an item in a list
Thread began 4/09/2013 12:33 pm by Dennis | Last modified 4/12/2013 3:26 pm by Dennis | 1583 views | 11 replies |
Dennis
I have a database that contains dogs name, year achieve AKC Champion, and kennel name.
I would like to enhance the search (or create a new search similar to) found here http://www.oldenglishsheepdogclubofamerica.org/champions_titled.php so when a year was imputed, the search results would display a column indicating the number of occurrences of a particular kennel name and sort by that column. So the end result would produce a list as can be seen in the first column found here (this is a static page created manually) http://www.oldenglishsheepdogclubofamerica.org/statistics/kennels_producing_champions.php.
The main part I am having trouble with is the calculating/displaying the number of occurrences of each kennel name.
Thanks,
Dennis
you would need to use a nested recordset for this.
in the nested recordset you would use the count function to return the record count.
see the following tutorial for details on nested recordsets:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=12
the W3Schools page has details on using the MySQL Count function
http://www.w3schools.com/sql/sql_func_count.asp
Dennis
Thanks Jason,
I think I have a good start with the nested recordset and Count function.
I'm having trouble with what to use for the WHERE clause in the nested (Count) recordset.
Also, how can I prevent the repeating of the same kennel names, and lastly how can I sort on the Count column.
Here is the link: http://www.oldenglishsheepdogclubofamerica.org/top_kennels_WA.php and attached is the file.
Thanks,
Dennis
top_kennels_WA.zip
to prevent repetitions, and to order by the count, we'll need to do this a different way using only 1 recordset:
SELECT *, COUNT(idColumn) as recordCount FROM tableName GROUP BY kenelNameColumn ORDER BY COUNT(idColumn) ASC
Dennis
Wonderful
Jason, that did the trick.
One thing that would be the icing on the cake, if it isn't to difficult, would be to have a second level sort on the kennel name. So the primary list sort would be by Count (which it is now) but within the same Counts the kennels would be sorted alphabetically.
Can that be done without to much difficulty?
Also could a TOTAL of all the counts be added.
Thanks,
Dennis
SELECT *, COUNT(idColumn) as recordCount FROM tableName GROUP BY kenelNameColumn ORDER BY COUNT(idColumn), kenelNameColumn ASC
for the total count, you would need a second recordset:
SELECT COUNT(idColumn) as recordCount FROM tableName
Dennis
So close...
Jason,
Sorting and everything but the total of counts is working great.
But for the Total count I get the total of the columns in the database, not the totals from the query listed on the page.
I even tried substituting the alias in the first recordset for the COUNT (columned) in the 2nd recordset, but I get a MySQL error for that.
Dennis
top_kennels_WA.zip
I guess i dont follow what you want to accomplish, I thought you wanted to show the total records from the database?
Dennis
Jason,
I want to display the total of all the counts (champions) displayed on the page by the recordset you helped me with. So if the search displays...
Kennel A 5 champions
Kennel B 4 champions
Total 9
To show the TOTAL you suggest the code (recordset) SELECT COUNT(idColumn) as recordCount FROM tableName
which makes sense, but I don't have an idColumn instead the recordset you suggested (reply #4 above) to create the list of champions uses an alias (I believe). Using that alias in place of idColumn gives an MySQL error.
The page can be seen here (I don't know how to make it a link with the new forum) - http://www.oldenglishsheepdogclubofamerica.org/top_kennels_WA.php
Dennis
I see now, change the recordset code:
$query_rsTotalCount = "SELECT COUNT(champions_id) as totalCount FROM champions";
$rsTotalCount = mysql_query($query_rsTotalCount, $connOESCA) or die(mysql_error());
setQueryBuilderSource($query_rsTotalCount,$WADbSearch1,false);
