Upload, Default HELP
Thread begun 4/07/2013 11:54 am by Cologne | Last modified 4/09/2013 7:29 am by Jason Byrnes | 1441 views | 4 replies |
Cologne
I nearly go crazy, or its too late.
When people register, they upload an image. (random-name).
In the backend they can change the image.
So, I set a hidden field (current-image) and store the current-image-name in it.
In the upload behavior I choose overwrite.
For File name I choose current-image from the hidden field.
And for default, too.
But this does not work.
It puts another .jpg at the end.
What am I doing wrong. I just want to keep the image name and let people update their profile, with or without chnaging the image.
Help!
Denis
The File Name setting should not include the file extension, this will be taken from the uploaded file, or if the form is being converted for images, from the selected format settings.
in the file name, setting use str_replace to strip the .jpg extension from the value of the hidden element:
change:
'FileName' => "".((isset($_POST["currentImage"]))?$_POST["currentImage"]:"")  ."",
'FileName' => "".((isset($_POST["currentImage"]))?str_replace(".jpg","",$_POST["currentImage"]):"")  ."",
Cologne
Hi Jason,
this does the trick.
I thought myself I could use it with the 2 fields, the simple file name and the server filename, but yours is better :-)
Thanks a lot!
Denis
ps. niw I dont need the 3 delete behaviors :-)
glad to hear it is working
