Framework-Servervalidation German Charachters
Thread began 4/07/2013 9:32 am by Cologne | Last modified 4/09/2013 10:31 am by Jason Byrnes | 721 views | 4 replies |
Cologne
since I try to use the FrameWork I run into trouble with the servervalidation.
I use alphanumeric validation with the german charachters allowed. ÜÖÄüöäß
Now, when I use in the framework, the validation wont work anymore.
Template is UTF-8 and my normal page without framework is also UTF-8
But the code is diffrent.
How can I delete the Framework from my pages and only use the normal templates?
this is so horror!
Denis
To remove the Framework builder theme, open the server behaviors panel. select the Theme server behavior and click the minus button to remove it.
Cologne
:-) sometimes its so easy, I deleted all by hand :-D
Can this be changed in an update or so?
Cheers,
Denis
Can what be changed in an update?
