MD5 with salt?
Ok after searching the forum I am thinking this can't be done as the redirect page says login failed. Anyways, the database I am connecting to (and cannot be changed) is using a email field (varchar255), a password field (char32) with MD5 encryption and a password_salt field (char3). Looking at the only user (1 record)...which is the admin the password_salt field data is "=0=" which I assume would be the same for all user.
I was able to create the form and the redirects forms but having no success in an actual success for a login. I am assuming because I have to use MD5 for the encryption for the password field and that does not generate the extra file in the webassist folder called "wa_securitykey.php" which I guess is required for salt. Is there anyway to hardcode it.
Thank you in advance for your time.
John
