Returning to Results page default filter settings after Search
Thread began 8/12/2009 12:14 pm by Kevin373660 | Last modified 8/12/2009 5:25 pm by Jason Byrnes | 1465 views | 1 replies |
Kevin373660
Using DataAssist Wizard, php and MySQL.
My Results page(s) incorporates some of the same Search fields from the Search page in it. I find it very handy option to include while running the Wizard. After running the search functions from either the page, and even flushing the browser cache manually, I have to open a new browser and reload the original Results page to get the default configured filtering results. The variables are set to the last search criteria. What options do I have to return without opening a new browser window? Like a master Results page that takes you to a separate sub-results page when you do a search, then link back to the main page? Simply run DataAssist to create a Results (home/index) page only. Or a reset button on the Results (not sure if I would use DW search for a second search on the same page)?
I would like this for my admin area but it also be applied for a catalogue shop/index main page that shows the features but also includes search functionality on the page. I could then redirect to a specific sub-Results page.
The search results are stored in a session variable named "$_SESSION["WADbSearch1_Products_Results"]"
you could create a reset link to the results page that contains a querystring variable, ans unset the session variable if that querystring variable is set. for example, create the link:
html:
<a href="results.php?search=reset">Reset the Results</a>
then create the following code at the top of the results page:
if(!session_id()) session_start();
if(isset(
$_SESSION["WADbSearch1_Products_Results"]) && isset($_GET['search']) && $_GET['search'] == "reset") {
    unset(
$_SESSION["WADbSearch1_Products_Results"]);
