Adding New Form Filed
Thread began 4/03/2013 4:12 am by Daniel | Last modified 4/03/2013 10:57 am by Jason Byrnes | 843 views | 3 replies |
Daniel
HI
I have used the below fields for registration but I would like to add Dj Name, Dj profile and an upload section ?
First Name
Last name
Phone
Email
Password
Question 2
I would like to show the dj profile information live on a page palled from the databass how is this done
You would need to edit the users table to include these new fields, then edit the registration page to add the form fields, go to insert -> Form and select the appropriate field type.
for the upload, you would need t add the Data Assist File Upload behavior (webassist -> File Manipulation -> File Upload)
then edit the insert record behavior to bind the new form elements to the new database columns.
for the image filed, bind the image column to the WA Uploaded Files -> Server File Name binding
Next, you would have to update the profile page. Edit the recoredset to include the new column in the select statement, and use the bindings panel to show the information on the page.
Daniel
Thanks ill get on that next
can you help on this error
opera after sign out I can hit the back button and still be signed in
after signing out and you get the message No record found. i need to still the footer and add more padding to push the footer down like the other pages? and the sign out link is still showing and not the sign in one?
please see justvibe.co.uk
using the browsers back button perform the action that loaded the page to begin with.
it uses the browser history to display the page.
since the history of the page is from when you where logged in, that is what you see.
There is not a work around for this, it is the behavior of the browser, and the way the browser works.
