Form Action (encrypted password)
Thread began 4/02/2013 12:04 pm by Cologne | Last modified 4/02/2013 1:55 pm by Cologne | 1430 views | 4 replies |
Cologne
Hello Jason,
can you tell me, if I can use this FORM ACTION anytime I use IDs in the URL to uldate?
<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>?<?php echo preg_replace("/^&/", "", preg_replace("/&?invalid=true/", "", $_SERVER["QUERY_STRING"])); ?>
When I use this
The update or delete of my recorset does not work.
Is the first one ready to use on every update or delete? I dont understand the first FORM ACTION. In my case I only use ID as integer parameter.
Cheers,
Denis
use this for the action if you want to preserver Query string variables:
 action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != ""?"?".htmlentities($_SERVER["QUERY_STRING"], ENT_QUOTES):""); ?>"
Cologne
Thanks a lot.
so the first one is only for the RETURN PAGE of the Mail Encrypted Password behavior?
the first one will keep the URL variables, but it has extra code to remove the "invalid=true" url variable from a failed validation.
Cologne
Thanks a lot Jason!
