checkbox not sending to database
Thread begun 4/02/2013 6:43 am by phill401410 | Last modified 4/17/2013 7:05 am by Jason Byrnes | 4040 views | 9 replies |
phill401410
I always have a problem getting a checkbox group to populate a database. Can you please help with this. At JetBoats-GroupForm.php
I am interested in information on (check all that apply):
Dells Boat Tours Jet Boat Adventures Original Wisconsin Ducks
and
Regarding (check all that apply):
Group Tours School Tours Charter cruises Special event venues
are not sending info to the database. Files attached.
thank you
I'l have to look into this with you in a screen sharing session
phill401410
Jason
In the form http://02e98e2.netsolhost.com/jetboats2013/JetBoats-GroupForm.php that sends to table jetboats2013 I changed all database table structure types to varchar. This enabled all $WA_columnTypesStr to be none as opposed to some being none,none,NULL. When I did this values for tours_Interested_In and regarding_Tours passed to the table. That's the good news, unfortunately they passed their values to table columns dateOutingEvent and notDeterminedDate.
I also tried adding tours_Interested_In and regarding_Tours or add [tours_Interested_In] and [regarding_Tours] to $WA_fieldNamesStr and got an error. Leaving them out passes values.
Files attached, thank you.
I'll need to investigate this with you.
phill401410
Thank you
I did not see your message till it was already passed 9am your time. is there another time you are available.
phill401410
Thank you for getting back to me.
In a screen sharing session, we found that there was a leading space in the column name in the MySQL Database " tour_Interested_In" that was causing the issue.
