DELETE FILE - only if field is not empty
Thread begun 3/25/2013 12:01 pm by Cologne | Last modified 3/26/2013 10:48 am by Jason Byrnes | 2596 views | 4 replies |
Cologne
I need so more trigger.
It is up to the user if he uploads an image. So the field can be blank.
I the user wants to delete his account I need to delete the images, too, IF there is one.
So, I need a trigger, if the
<?php echo $row_imageName['image']; ?>
is empty or not, and then the button pressed trigger.
how does that work?
Denis
Cologne
OK; I think I got it.
I used $_POST[myHiddenField] as trigger and it triggers if not empty, so this works.
do I need to take care for something else?
Cheers,
Denis
That should work.
Cologne
This works.
I need some advice, or better, am I doing right.
The user can upload an image on a profile update page. Will say, the image filed is empty.
And I store nothing in the hidden field for the current image.
The new image, if the user uploads an image gets a random password (SA) that I store in a session when button pressed.
So, am I right, that I need 2 triggers for the old image delete function?
Cause, if the hidden field for the current image is empty I get an error message.
Then I need an other trigger to check if an upload was done, to delete the old image.
if there is no image, take the hidden field (current image) as default in the upload, and so it stays empty.
in case of upload a new image, the hidden field is not empty, the upload is done, so the old image can be deleted.
is this the right way, or is there an other, better way to do this.
Cheers,
Denis
you could add an additional if statement around the delete file behavior so it only triggers if a a file name exists in the data base:
<?php if($row_recordsetName['imageColumn'] != "") { ?>
<delete file code>
<?php } ?>
