How to Remove Menu
Is there a tutorial somewhere that explains how to remove a CSS menuwriter menu from a Site Sculptor site, so I can replace with a different menu product?
no, there is not a tutorial for removing the menu.
if it is a php page, there will be a require once line to point to the menu include file, remove that to remove the menu contents.
if it is an html page, the menu contents will be a UL tag on the page, remove the menu UL and LI tags to remove the menu contents.
other than that there is code to link the css files that needs to be removed.
