Diffrent Server Behavior For Same Way
Hello,
I want to know why the ServerBehavior looks diffrent, even if I use the same way to create my email massage with a template?
See attached files.
Cheers,
Denis
Hello,
See attached files.
Cheers,
Denis
In one screen shot you selected the mailContact Email body template file, in the other you selected the mailRegister email template file.
Thais right, the Path that is shown in the behavior is diffrent.
It says One Time Mail, and the other Time /mailContact
Hi Jason,
sorry for coming back to this threat.
It is still diffrent :-)
Image 1 says, I use my own template (filename is: registerMail.php)
But if you look to the right in the behaviors panel, it says mail, thats not correct.
If you look image 2, there the filename is written in the behaviors panel. contactMail.php
that is what i dont undersand :-(
what is the file name for the selected template file?
Image 1: registerMail.php
Image 2: contactMail.php
I really cant say why the server behavior list shows the template name differently, does the email get sent correctly?
Hi Jason, yes the email is sent correct, but this is so strange :-(
what can it be?
maybe its because its called register?
Then I thought its always the first email behavior I use on the page, but thats not the faux. its only in the case :-)
I honestly have no idea, but the email works, so there is not a problem.
