Framework syntax error and blank page
Thread began 3/15/2013 2:53 pm by Brad Lawryk | Last modified 3/18/2013 6:40 am by Jason Byrnes | 865 views | 1 replies |
Brad Lawryk
Hi guys,
Been awhile since I needed the extensions so I updated them and started a new site.
When applying the dynamic plugins it generates a syntax error in the code and then the page does not load at all.
See screenshot:
In the Dynamic Plugin settings, For the trigger variable, you should click the lightning bolt to select a variable from the bindings list to use as the plugin trigger.
It looks like you typed "View" rather than selecting a variable to use.
