Cart Description
Thread began 3/07/2013 10:27 am by please_help | Last modified 3/07/2013 11:07 am by please_help | 654 views | 2 replies |
please_help
Cart Description
Hello~
I would like to change the field referenced for the description on the cart page. It currently references the short description from my database, but I'd like to change it. I've looked everywhere I could think to find the correct code, but am not finding it....
that is set in the Add To Cart server behavior.
on the page that has your add to cart button, open the bindings panel and double click the eCart Add to Cart server behavior. on the bindings tab, you can chose the column that is used for the Description column.
NOTE: You will most likely need to clear the cart before testing the change if you have already added items to the cart.
please_help
Excellent!
Thanks so much!
