Dynamic field required in image title
Thread began 3/07/2013 6:02 am by john70964 | Last modified 3/07/2013 2:05 pm by john70964 | 778 views | 2 replies |
john70964
I am using a dynamically created image.
I use a Title= in the image code and I tried to get a table field to show as well as "Click to see LARGER PICTURE".
I tried to get a field to show but could not see to do this. Is there a way I can get the Title to show a table field?
The code is:
<td><p><a href="indexPic.php?RecNo=<?php echo $row_rsPrimeImage['RecNo']; ?>"><img src="Images/<?php echo $row_rsPrimeImage['Image1_250']; ?>" alt="for sale image 250" width="200" title="Click to see LARGER PICTURE"/></a><br />
<span class="main"><?php echo $row_rsPrimeImage['Manufacturer']; ?> <br />
<?php echo $row_rsPrimeImage['Model']; ?><br />
<input type="submit" value="Larger Image" class="BFSN" id="Boat_Large" name="Boat_Large" />
</a>
<a href="BoatResultsDetail.php?recordID=<?php echo $row_rsPrimeImage['RecNo']; ?>">
<input type="submit" value="More Info" class="BFSN" id="Info" name="Info" />
</a></span></p>
<hr /></td>
Many thanks
John
change:
title="<?php echo $row_rsPrimeImage['Manufacturer']; ?>"
or use a different recordset column if you like
john70964
Excellent
Many thanks
John
